Issue with RaiDrive Pro local drive Remote application
Hi Everyone,
I have purchased RaiDrive Pro to mount a local drive via a server. I successfully connected RaiDrive using WebDAV and SFTP and can access it through various clients.
However, I encounter an issue with a remote program that I use. When I connect the RaiDrive local disk via the remote program, I receive an error, and the program closes itself. When I disconnect RaiDrive, the program works without any issues.
Does anyone know what might be causing this problem or if there is a workaround?
Thank you.
Hello. administratie.
Please send us the information below via email (support@raidrive.com).
  1. Please capture the error message screen.
  2. Please capture the drive settings screen of RaiDrive.
  3. Please tell us what the remote program is.
  4. Please compress and send us the log folder below.
Thank you.
