Hello. I’m having an error after opening raidrive as shown on print. When opening the software it gives this error and doesnt let me do anything. How can I solve it? Already tried to reinstall and it didnt worked. Thank you
Hi @Paulo,
It looks like the Microsoft Edge WebView2 Runtime needs to be repaired.
In Settings > Apps > Installed apps, click on the ... at the end and click Modify.
And then click the Repair button
If the Microsoft Edge WebView2 Runtime is not listed in the installed apps, you need to change the value of SystemComponent to 0(zero) in the HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft EdgeWebView.
After repairing, please reset the value of SystemComponent to the original.
That worked! Already running smoothly.
Thank you very much for your help!
