When you connect via webdav to owncloud server and open an office document (word, excel, …) the file is not locked in the server and other user can open the file in read-write mode.
Screenshots of config:
Hi~ @ronbailer ,
Have you set up a file lock on both PCs?
You must set the file lock on both PCs so that it works normally.
Please check and tell us the results.
Yes, i have set the lock option on both PCs.
I have tried the Owncloud webdav locks with Windows native client, Mountain duck and Webdrive and all of them works propertly. But in Raidrive the behaivor with lock option and without this option is the same. The file never is locked.
Hi~ @ronbailer ,
We’re trying to verify what you said.
Two pieces of information are required for accurate identification.
If you send us two pieces of information by email(support@raidrive.com), we will check it and get back to you.
Yesterday I sent you the two pieces of info.
Thank you
Hi~ @ronbailer ,
The mail did not arrive. Please send it again.
I have forwarded the email, thanks!!!
Is there any news about it?
Hi~ @ronbailer ,
Thank you for reporting the issue.
The Lock issue of Owncloud will soon be modified and distributed.
Thanks a lot.
Best regards
