I used the Pro version of RaiDrive with WebDAV and active option “Monitor process access to files”.
On Windows (WebDAV) it gives me a warning when opening Word/Excel files if someone else has already opened them. This does not happen under RaiDrive, although the option is activated.
That there is a warning that someone else has saved the file in the meantime is okay, but it comes too late, especially if you have already changed a lot in a file. The option of a backup copy does not remain there either.
Is there a possibility to receive a warning when opening Word / Excel files, if they are in the current access of another user, as usual with Windows integration?
Thanks,
Tilo
