Hi…Maybe a bug or normal…Why does it show storage EB and not TB??? Uloz.to has 5 lists (5TB, 25TB, 50TB AND 100TB)…Thank you
Hi, @Houfino_Knight
Uloz.To API does not provide the user’s allocated capacity and usage information.
Therefore, RaiDrive provides the maximum amount of capacity information that can be displayed in the window.
If you want to change this displayed capacity information, you can change it in the drive settings.
Please refer to the document below.
