Version: 2025.7.16
RaiDrive Mount
Unable to register module C:\Program Files\OpenBoxLab\RaiDrive
Mount\RaiDrive.ShellExtension.x64.comhost.dll. HRESULT
Status: In Progress
-2147024770. Please contact your technical support personnel.
Hi, @zhanghao520111
This error is usually caused by a Microsoft .NET issue or a Windows update issue.
First, update Windows.
Then, install the latest version of .NET 8 from the link below:
Download and install the version appropriate for your PC’s environment from the .NET Desktop Runtime 8.0.19 section.
Other users have reported that the installation was successful after canceling the last Windows update.
An antivirus program may also be blocking the installation. Please temporarily disable the antivirus program and try installing again.
If the issue persists, please let us know.
