Hi folks,
without changing someting i get the following error message when try to connect to sftp:
The object reference was not set to an object instance.
(Unfortunately i get it in my native language [German] indipendently from the RaiDrive language.)
Any ideas what this means? I can access my sftp from other programs without restrictions.
Best regards & thx in advance.
may help to post the original error message in german:
Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
please help…
Hi~ @torsten_jungmann ,
We need a log file to check the issue you mentioned. Please send the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) by e-mail(support@raidrive.com) and We will tell you again after checking.
Please try the latest version, and if the problem persists in the latest version, please send the log(C:\ProgramData\OpenBoxLab\RaiDrive\log) again by e-mail(support@raidrive.com) and we will check it and tell you again.
Thx a lot it works pretty perfect now (again)!
