I’m currently travelling and my NAS drive has failed. There’s no one I can contact to fix it at the moment.
RaiDriveis continually attempting to connect to the drives mapped on the NAS.
Is there a way to temporarily disable RaiDrive from trying to connect? It’s doing it every few minutes and I have to click cancel each time.
Hi, Taras_Pich.
Please try unchecking the “Reconnect at program start” option in the drive settings.
If the problem is not resolved, please zip the log folder below and send it to us by email( (support@raidrive.com).
- C:\ProgramData\OpenBoxLab\RaiDrive\log
If possible, please capture the drive settings screen and error screen and send them to us.
Thank you.
That did it. Forgot about that setting.
Thanks
