RaiDrive won’t allow the save as or rename operations for files/documents during periods of time then it works just fine again. Are there any known issues/workarounds?
Using Version 2026-6-25
Thanks for any ideas or help!
Hi @5P_User
Please test again using the test version below.
Please reboot your system after installing the test version.
If an error occurs after testing, please compress the log folder below and send it to support@raidrive.com.
C:\ProgramData\OpenBoxLab\RaiDrive Mount\log
If an error occurs when compressing the log folder, or if the service.log file is missing from the compressed result, please copy the log folder first and then compress the copied folder.
If you send us the logs, we will analyze them and get back to you.
