Hello, I use Raidrive for long time to connect to my SFTP Server (Syncplify.me).
There were no problems up to now, but with current version of RaidRive 2020.2.12 my connection is not working properly. After entering remote drive I can enter some folders but after few moves folders becomes empty ( there should be files ) and I can’t go back to root directory and in fact nothing work, even can’t disconnect.
There were no problems in previous versions of raidrive, maybe it’s something with RebexSSH library?
Here is what my server displays about client connection - looks like this rebexSSH is newer then before.
One more question: Is there a way to download somewhere previous versions of RaiDrive? Can’t find anywhere.
@daslicht, it’s probable caused by the concurrent connection(socket).
We will consider that the number of connection can be adjusted in the future version.
A log file is required to check the phenomenon you mentioned.
If you send the log file by e-mail(support@raidrive.com), we will tell you again after analysis.
