During install of RaiDrive_2023.9.209.1_x86 I get the following error:
Problem summary: INTERACTIVE is not a valid usergroup.
How do I solve this?
Thanks,
Kees.
Thanks,
Kees.
Hi @cp.vernooij,
To install RaiDrive package, an account has the privilege of Administrator.
Thanks, I did not try that.
However, “run as Administrator” gives the same error message.
Any other solution?
Thanks,
Kees.
Is this an account registered with AD(Active Directory)?
Probalby the problem lies there.
I did some research on the internet for similar errormessages and came across a similar problem for “Authenticated” users, where the solution was to add the usergroup.
So I tried: net localgroup /add “INTERACTIVE”
and clicked Retry and then the installation finished successfully.
However, Launch of Raidrive gives the following error:
“Can’t get access to the device, path of file.”
Apparently some authorizations have to be added to the group.
I re-installed Raidrive and that went well, but startup gives the same problem.
Do you have an idea how to solve this problem?
INTERACTIVE Group in Windows operating systems is a special group that users are automatically added to when they log in directly to the system. This group is primarily used for security and permission management , and users in this group are considered to have logged in locally.
You had to better to ask your system administrator because this issue is about security policy.
I see.
This a small private laptop so I am the system administrator. I will look further for a solution.
Thanks for your help,
Kees.
I still come back to you one more time.
On my Windows 10 64bit, there is no localgroup INTERACTIVE either, but Raidrive 64bit installs without a problem.
Why does Raidrive 32bit needs this group on Windows 10 32bit?
Any idea?
Thanks,
Kees.
