Get error “RaiDrive setup ended prematurely because of an error.”
No other software application causes this error
Hi @stevench,
Could you try to remove Microsoft Visual C++ Redistributable and install again?
Removed all Visual C++ and rebooted. Same error.
Could you share a screenshot?
Is there any dialog message before this screenshot?
It just starts the install process, like exacting files, then stops and pops up the message.
Could you update .NET Desktop Runtime to 6.0.31?
If some kind of virus detector (e.g. Avast, Norton) is running, please stop temporarily on installing.
I did that. No change.
RaiDrive appears to extract and then fail.
