Raidrive vs. Onedrive Business vs. Autocad Civil3D
Hello!
Over the last two weeks, we have been experiencing issues with RaiDrive. The main problem is that opening files from the RaiDrive mount folder is painfully slow. This also affects our work in AutoCAD — opening files or using template files from our server (RaiDrive) causes the entire program to freeze.
It appears to be a RaiDrive issue, as even opening a simple .pdf file takes an unusually long time. We have attempted a clean uninstall and reinstall, but the problem persists. This was not an issue a month ago. What has changed, and why is this happening?
Hi, @energy
Please compress the log folder below and send it to support@raidrive.com.
If an error occurs when compressing the log folder, or if the service.log file is missing from the compressed result, please copy the log folder first and then compress the copied folder.
Please test with the patch version below.
If the issue persists, please send the logs again.
Still unresolved. I sent logs and images.
I have sent you a version via email that records detailed logs.
Please check your email.
Sent all the data via email.
It seems that the reported issue is linked also with the performance issues affecting the WebDav connectivity that has been reported in another thread. There is clearly something wrong with the latest version. The same behavior is happening also for me and others that are using Raidrive with Synology NAS Webdav servers.
Has there been a resolution to this? we just bought the software today and about to cancel on multiple systems software will start to open Cadd files and Crash while it seems like its downloading the file.
