I’m using my raidrive as a local disk on my Plex server but the drive keeps disconnecting after a certain number of scans have taken place.
Hi~ @Sheldon_Lewis1,
We are testing the Plex Media Server operation.
Could you send the log files(C:\ProgramData\OpenBoxLab\RaiDrive\log) when disconnecting?
2019-11-10 21:45:54.050 [INFO] == RaiDrive Service Starting : Version : 1.8.0.0(64Bit) IsServer : True IsWindows7 : False ==
2019-11-10 21:45:54.050 [INFO] PROGRAM START : START MAIN PROCES
2019-11-10 21:45:54.066 [INFO] SYSTEMINFO : OS : Windows Server 2016 Standard (Microsoft Windows NT 10.0.14393.0) : x64
2019-11-10 21:45:54.113 [INFO] SYSTEMINFO : Language : English (United States)
2019-11-10 21:45:54.113 [INFO] PRODUCT NAME : RaiDrive : DATA PATH : C:\ProgramData\OpenBoxLab\RaiDrive
2019-11-10 21:45:58.941 [INFO] MAIN : START WINDOWS SERVICE
2019-11-10 21:45:59.223 [INFO] MAIN : START
2019-11-10 21:45:59.238 [INFO] MAIN : FILE SYSTEM DRIVER INIT
2019-11-10 21:45:59.238 [INFO] DRIVEMANAGER : CACHE FOLDER INIT : C:\ProgramData\OpenBoxLab\RaiDrive\Cache
2019-11-10 21:46:03.473 [INFO] DRIVEMANAGER : MAIN READY
2019-11-10 21:46:03.473 [INFO] MAIN : FILE SYSTEM DRIVER Version : 6.1.184.118
2019-11-10 21:46:03.473 [INFO] SERVICE : START DONE
2019-11-10 21:46:04.208 [INFO] REMOTE SESSION CONNECT : 1
2019-11-10 21:47:05.308 [INFO] REMOTE SESSION CONNECT : 2
2019-11-10 21:47:05.590 [INFO] SESSION LOGON : 2
2019-11-10 21:47:23.112 [INFO] CS : CLIENT CONNECTED : 1
2019-11-10 21:47:33.041 [INFO] DRIVEMAN : Client Register : CBFS Install Test Success
2019-11-10 21:47:34.797 [INFO] CLIENT LOGIN SUCCESS : 1
2019-11-10 21:47:34.797 [INFO] DRIVEMAN : LOGIN Success
2019-11-10 21:48:20.690 [INFO] USER LOGOUT
2019-11-10 21:48:20.721 [INFO] DRIVEMAN : Client Register : CBFS Install Test Success
2019-11-10 21:48:22.441 [INFO] CLIENT LOGIN SUCCESS : 1
2019-11-10 21:48:22.441 [INFO] DRIVEMAN : LOGIN Success
2019-11-10 21:48:25.624 [INFO] LICENSE SESSION Connect Success
2019-11-10 21:48:58.312 [INFO] CONTROLLER: Shared drives : User Cache Folder : C:\ProgramData\OpenBoxLab\RaiDrive\Cache\1b4b9c7d-351b-47cf-8253-cf3b0d6220db
2019-11-10 21:48:59.014 [INFO] DefaultDriveChanges loaded successfully
2019-11-10 21:48:59.575 [INFO] Lambda Drive Changes Configuration loaded successfully
2019-11-10 21:48:59.590 [INFO] GoogleTeamDrive (Shared drives) : Check Remote Changes State : True
2019-11-10 21:48:59.590 [INFO] GoogleTeamDrive (Shared drives) : Drive Created
2019-11-10 21:48:59.717 [INFO] CONTROLLER: Shared drives : Remote Drive Make Success
2019-11-10 21:49:01.913 [INFO] CONTROLLER: Shared drives : Remote Drive Authentication Success
2019-11-10 21:49:01.930 [INFO] CONTROLLER: Shared drives : Create Success
2019-11-10 21:49:01.953 [INFO] FILESYSTEM : Shared drives : INIT DONE : DriveLetter : O:, IsNetwork : False, IsGlobal : False, IsReadOnly : False, UseRecyble : True
2019-11-10 21:49:01.953 [INFO] CONTROLLER: Shared drives : Init Success
2019-11-10 21:49:01.991 [INFO] FILESYSTEM : Shared drives : MOUNT STATE : DriveLetter : O:, IsNetwork : False, IsGlobal : False, IsReadOnly : False, UseMountManager : False
2019-11-10 21:49:02.011 [INFO] FILESYSTEM : Shared drives : CreateStorage Success
2019-11-10 21:49:02.056 [INFO] FILESYSTEM : Shared drives : Get Volume Label : Shared drives
2019-11-10 21:49:02.060 [INFO] FILESYSTEM : Shared drives : MountMedia Success
2019-11-10 21:49:02.103 [INFO] FILESYSTEM : Shared drives : MountPoint Add O: Success
2019-11-10 21:49:02.110 [INFO] CONTROLLER: Shared drives : Mount Success
2019-11-10 21:49:02.133 [INFO] CONTROLLER: Shared drives : Drive Connect Success
2019-11-10 21:49:03.055 [INFO] GoogleTeamDrive (Shared drives) : Check Change Thread Start
2019-11-10 21:58:26.319 [ERROR] GoogleTeamDrive API : Shared drives : Download Error: Code : InternalServerError MSG : {
“error”: {
“code”: 500,
“message”: null
2019-11-10 22:16:04.255 [ERROR] GoogleTeamDrive API : Shared drives : Download Error: Code : InternalServerError MSG : {
“error”: {
“code”: 500,
“message”: null
2019-11-10 22:17:38.891 [ERROR] GoogleTeamDrive API : Shared drives : Download Error: Code : InternalServerError MSG : {
“error”: {
“code”: 500,
“message”: null
2019-11-10 22:25:17.502 [ERROR] GoogleTeamDrive API : Shared drives : Download Error: Code : InternalServerError MSG : {
“error”: {
“errors”: [
“domain”: “global”,
“reason”: “internalError”,
“message”: “Internal Error”
“code”: 500,
2019-11-10 22:47:55.493 [ERROR] GoogleTeamDrive API : Shared drives : Download Error: Code : InternalServerError MSG : {
“error”: {
“code”: 500,
“message”: null
2019-11-10 22:53:06.803 [INFO] REMOTE SESSION DISCONNECT : 2
2019-11-10 22:53:06.836 [INFO] Remount : Delete Mount Succes : O: : 268435456 : 238553
2019-11-10 22:53:06.836 [INFO] Remount : Delete Mount Succes : O: : 268435456 : 238524
2019-11-10 22:53:06.836 [INFO] Remount : Add New Mount Succes : O: : 268435456 : 999
2019-11-11 01:58:38.864 [INFO] REMOTE SESSION CONNECT : 3
2019-11-11 01:58:43.466 [INFO] REMOTE SESSION DISCONNECT : 3
2019-11-11 04:44:14.676 [ERROR] GoogleTeamDrive API : Shared drives : HTTP ERROR : BadRequest : ERROR : Bad Request : RESPONSE : [{
“error”: {
“errors”: [
“domain”: “global”,
“reason”: “invalid”,
“message”: “Invalid value for: Invalid format: “0001-01-01T00:00:00” is too short”
“code”: 400,
2019-11-11 04:44:14.676 [ERROR] GoogleTeamDrive API : Shared drives : Create Team Drive Error : Status : BadRequest : ResponseBody : {
“error”: {
“errors”: [
“domain”: “global”,
“code”: 400,
2019-11-11 04:44:16.720 [ERROR] GoogleTeamDrive API : Shared drives : HTTP ERROR : BadRequest : ERROR : Bad Request : RESPONSE : [{
“error”: {
“errors”: [
“domain”: “global”,
“code”: 400,
2019-11-11 04:44:16.720 [ERROR] GoogleTeamDrive API : Shared drives : Create Team Drive Error : Status : BadRequest : ResponseBody : {
“error”: {
“errors”: [
“domain”: “global”,
“code”: 400,
2019-11-11 04:44:20.758 [ERROR] GoogleTeamDrive API : Shared drives : HTTP ERROR : BadRequest : ERROR : Bad Request : RESPONSE : [{
“error”: {
“errors”: [
“domain”: “global”,
“code”: 400,
2019-11-11 04:44:20.758 [ERROR] GoogleTeamDrive API : Shared drives : Create Team Drive Error : Status : BadRequest : ResponseBody : {
“error”: {
“errors”: [
“domain”: “global”,
“code”: 400,
2019-11-11 04:44:20.758 [ERROR] GoogleTeamDrive API : Shared drives : Create Team Folder Failed : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:"",“Filename”:“MSIf29ca.tmp”,“WebResponseCode”:400,“HttpException”:“400 File Invalid : invalid”,“HttpReferenceMessage”:"{\n “error”: {\n “errors”: [\n {\n “domain”: “global”,\n “reason”: “invalid”,\n “message”: “Invalid value for: Invalid format: \“0001-01-01T00:00:00\” is too short”\n }\n ],\n “code”: 400,\n “message”: “Invalid value for: Invalid format: \“0001-01-01T00:00:00\” is too short”\n }\n}\n"}
2019-11-11 04:44:20.758 [ERROR] GoogleTeamDrive (Shared drives) : Create Team Error : MSIf29ca.tmp : Exception : {“WinErrorCode”:1237,“NotifyErrorCode”:205,“RaiException”:“Create Team Folder Fail”,“Filename”:“MSIf29ca.tmp”,“WebResponseCode”:400,“HttpException”:“400 File Invalid : invalid”,“HttpReferenceMessage”:"{\n “error”: {\n “errors”: [\n {\n “domain”: “global”,\n “reason”: “invalid”,\n “message”: “Invalid value for: Invalid format: \“0001-01-01T00:00:00\” is too short”\n }\n ],\n “code”: 400,\n “message”: “Invalid value for: Invalid format: \“0001-01-01T00:00:00\” is too short”\n }\n}\n"}
2019-11-11 05:04:25.935 [INFO] REMOTE SESSION CONNECT : 3
2019-11-11 05:04:26.467 [INFO] REMOTE SESSION DISCONNECT : 3
2019-11-11 05:04:26.964 [INFO] REMOTE SESSION CONNECT : 2
2019-11-11 05:04:26.967 [INFO] Remount : Delete Mount Succes : O: : 268435456 : 999
2019-11-11 05:04:26.968 [INFO] Remount : Add New Mount Succes : O: : 268435456 : 238553
2019-11-11 05:04:26.968 [INFO] Remount : Add New Mount Succes : O: : 268435456 : 238524
Google Shared drives seem that some operations are under the abnormal state which cannot be failed over. It might be caused by MSIf29ca.tmp file. Could you try again after removing this file?
I found the issue. So i’m using windows server 2019 standard. The behavior of the application when you disconnect from a remote session it disconnects the drive and remaps it. While during the remapping plex was running a scan for media. So plex scan thought that the media had “moved” so it deleted all and started over again. (stupid behavior I think)
My workaround is I created a secondary user configured raidrive on that account then I sign off completely. Logged into my plex (windows user account) and found that the drive was mapped and I could access it. Currently I have not yet to run across a random disconnect from leaving rdp session.
