The Use application lock feature is designed to protect application settings. When enabled, it locks the RaiDrive interface to prevent changes, while keeping the connected drives available.
If you would like the drives to be disconnected when you are away from your computer, please use the Disconnect after idel time option. This will automatically lock the application and disconnect the drives after the specified idle time, providing an additional level of security.
I would like to suggest a new feature related to application security. Currently, the Use application lock option only locks the interface while keeping the connected drives available, and the Disconnect after idle time option disconnects drives after inactivity.
It would be very helpful if there could be an additional option to connect drives only after unlocking the application. This would ensure that drives remain disconnected until the user explicitly unlocks RaiDrive, providing an extra level of security.
