Hey
the clients are losing settings, I sent logs by mail.
please help
Thanks
AMir
please help it happens after each shutdown
Hi~ @BGPC,
We’ve answered by e-mail.
If you have any questions, please let me know.
I have this exact same issue. I’ve tried reinstalling Windows. RaiDrive refuses to save any settings or profiles I’ve created. They’re all erased after I restart my computer and I have to re-import them again from my .dat backup.
Is there a solution that can be posted here?
Hi~ @Nathan_Dick ,
After importing the drive list, you must log in for each drive once again. Will the list of drives be cleared after logging in all drives?
Yes. Every time I have to import them, and login. After a restart of the computer, all the drives are still gone in the RaiDrive settings. (Settings are wiped completely)
Hey
After messing with it, the import feature was the problem on my case.
Don’t use it. Set each station from zero and it will save it.
I’ll give that a try. Maybe the team should look into that.
Hi~ @Nathan_Dick , @BGPC,
We sent an email with a new patch to hope to fix this issue.
We also have the same problem.
