Raidrive has error,how to solve it?
错误应用程序名称: RaiDrive.exe,版本: 2023.9.256.0,时间戳: 0x66df0000
错误模块名称: KERNELBASE.dll,版本: 10.0.22621.1194,时间戳: 0xfaa44dd0
异常代码: 0xe0434352
错误偏移量: 0x000000000009051c
错误进程 ID: 0x0x639C
错误应用程序启动时间: 0x0x1DC39BC8F2FCD6B
错误应用程序路径: E:\Program Files\OpenBoxLab\RaiDrive\RaiDrive.exe
错误模块路径: C:\windows\System32\KERNELBASE.dll
报告 ID: 3bcd7f4c-1417-4a3a-b92c-3505e43e214a
错误程序包全名:
错误程序包相对应用程序 ID:
Application: RaiDrive.exe
CoreCLR Version: 6.0.2423.51814
.NET Version: 6.0.24
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException: 关闭窗口后,无法设置可见性,也无法调用 Show、ShowDialogor 或 WindowInteropHelper.EnsureHandle。
at System.Windows.Window.VerifyCanShow()
at System.Windows.Window.CoerceVisibility(DependencyObject d, Object value)
at System.Windows.DependencyObject.ProcessCoerceValue(DependencyProperty dp, PropertyMetadata metadata, EntryIndex& entryIndex, Int32& targetIndex, EffectiveValueEntry& newEntry, EffectiveValueEntry& oldEntry, Object& oldValue, Object baseValue, Object controlValue, CoerceValueCallback coerceValueCallback, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, Boolean skipBaseValueChecks)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at System.Windows.UIElement.set_Visibility(Visibility value)
at NqlDJ4dd0ptT5937uXAj.bWodHlddODyurKLdsBpG.<>c__DisplayClass11_0.PXGU2KdtjQf8XyIntq94.CI4BLdGChS0wlkHWeIph(Object , Visibility )
at NqlDJ4dd0ptT5937uXAj.bWodHlddODyurKLdsBpG.<>c__DisplayClass11_0.PXGU2KdtjQf8XyIntq94.MoveNext()
— End of stack trace from previous location —
at System.Threading.Tasks.Task.<>c.b__128_0(Object state)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.MessageBox(HandleRef hWnd, String text, String caption, Int32 type)
at System.Windows.MessageBox.ShowCore(IntPtr owner, String messageBoxText, String caption, MessageBoxButton button, MessageBoxImage icon, MessageBoxResult defaultResult, MessageBoxOptions options)
at System.Windows.MessageBox.Show(String messageBoxText, String caption, MessageBoxButton button, MessageBoxImage icon)
at a2fNKCNTtlnokdT0n0w.P9e8AYNgfXZFl876fYe.gsg3r0wThpN5J69fHbUR(Object , Object , MessageBoxButton , MessageBoxImage )
at a2fNKCNTtlnokdT0n0w.P9e8AYNgfXZFl876fYe.OkSNexnaJH(Exception )
at a2fNKCNTtlnokdT0n0w.P9e8AYNgfXZFl876fYe.x6bNmX7XP4(Object , DispatcherUnhandledExceptionEventArgs )
at System.Windows.Threading.Dispatcher.CatchException(Exception e)
at System.Windows.Threading.Dispatcher.CatchExceptionStatic(Object source, Exception e)
at System.Windows.Threading.ExceptionWrapper.CatchException(Object source, Exception e, Delegate catchHandler)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.Run()
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run()
at a2fNKCNTtlnokdT0n0w.P9e8AYNgfXZFl876fYe.KXeijLwEnH0OlIcLykjF(Object )
at a2fNKCNTtlnokdT0n0w.P9e8AYNgfXZFl876fYe.W9fNCPhB2Y()
at {9B1C2493-9676-4230-B134-65C3BDBE799F}.Main()
Hi @lycxiaoleihacker,
Could you try to repair RaiDrive app in Settings > App > RaiDrive ?
I had already reinstalled Raidrive app for several times,but it still had this error.I think it is the software bug.
Could you try to repair WebView2 Runtime?
