some programs do not see the drives as physical hard drives and cannot do certain things. How can that be solved? would it be possible to install an application directly on the NAS drive?
Hi~ @felix_framit ,
If you subscribe to the Professional Edition, you can use the Local Disk function. You can try and pay for a one-week trial period.
If a issue occurs while using the local disk function, please let us know in detail which program is causing the issue.
RaiDrive is designed to work only on Windows systems.
It cannot be installed on the NAS.
