Onedrive not working. It gave permission, and it still will not connect?
I deleted it and redded it and still will not work
I also have same problem. bad gateway issue occured
Hi, @helee37 , @Gerry_Pomanski
This error appears to be a temporary error with the OneDrive API server.
Since this error is sent from the OneDrive API server, it appears to be a communication issue between OneDrive’s internal servers.
Current internal testing indicates no issues, suggesting a problem with some API servers or a temporary outage.
Please try again later and let us know.
It works now
Thank you
