I’m using Windows Pro 10 x64 build 1903 with RaiDrive 1.8.0.
After rebooting it started refusing the OneDrive auth showing this message.
Thanks!
Thanks!
Hi~ @Matteo_Abbia,
Verry sorry for the trouble.
It was a leakage for handling authorization token by RaiDrive.
We will fix in the next coming next version ASAP.
To avoid this issue you have to add a new OneDrive drive after removing the existing one.
