Would it be possible to let RaiDrive restrict the created mounted drive by .exe? Right now you can mount a cloud space by volume, and the entire system, including anything unwanted or hazardous, has access to that mounted drive. That seem ill-advised, especially since there are a lot of people that use these services as backups. I way to restrict who or what has access to that mounted volume share would prevent unwanted or malicious file deleting. For example, I’d prefer it if only rclone has access to my mega mounted volume.
Ok. Let’s try a different approach. Is there a way of scheduling Raidrive to connect to its share, so that it doesn’t have to be connected all the time. For me, there’s no need for it to be. Ideally, I’d create a script that has raidrive connect, then start rclone, and then have raidrive exit when rclone finishes. Is it possible to schedule raidrive via CL?
