Mount SMB folder as local disk
Hi ! Is it possible to add the feature of mounting smb storage as local disk ?
Hi~ @df488wkxpr,
Unfortunately, it’s not possible.
I can do it using this command “C:\Program Files\Dokan\Dokan Library-2.1.0\sample\mirror\mirror.exe” /r \192.168.1.201\Media /l F
With Dokan Library, so why can’t you do it ?
Other apps may support SMB directly. However, RaiDrive does not support SMB mapping.
