bonjour çà fait 3 jour que je tente de passer des fichier de mega ver ondrive et impossible votre jai nés jamais u autans de problème avec autre logiciel que ce lui ci ???
Transfers between MEGA and OneDrive (or GoogleDrive and Dropbox that I also use daily) work perfectly fine. Send a log or screenshots of your configuration. You’re probably doing something wrong.
Hi~ @sollier_jacky,
We’re trying to reproduce the issue you said.
Please send the log file (C:\ProgramData\OpenBoxLab\RaiDrive\log) and capture file when the issue occurs via e-mail(support@raidrive.com) and we will tell you again after checking.
