Why is it not working? I entered my name and password correctly and I have a subscription…What’s going on? Thank you
Hi @Houfino_Knight,
402 Payment Required
This is a message directly from MEGA services.
Could you check the status of your payment on MEGA.nz?
What??? I’ve been paying since 2015 until now…I remember that 2-3 years ago they worked and now they don’t work…It’s not mega.nz’s fault…It’s more like your fault…You should have tested mega to see if it’s ok or not
Could you check an email account or password of MEGA?
If login fails, this message will be changed to a more understandable sentence in the next version.
Login + verification works for me… But I can’t connect…It just throws a 402 error…
Could you send log files to support@raidrive.com?
- C:\ProgramData\OpenBoxLab\RaiDrive\log
Yes…I sent you an email.
It works now…I had a long password and a simple one…I had to change it to a more complex password and it works…I see that it’s strange :-O…It seems to work and glory
THANK YOU!!! Solved
@Houfino_Knight,
Thank you for your update.
This issue will be fixed in the next version so that you don’t have to change your password.
