Hi
First, thanks very much for your program!
My problem: when I activate WebDAV connection, I’m limited (35mo/s). I use local adress and I’m in local Network.
Can you tell me where check this point plz!
My system: Windows 11/ Nas Synology (DSM 6.2)
Thanks for your help
Regards
DBX
Plz, give the possibility to remove ADS…
Hi
Another information:
WebDAV in shttp= 35Mo/s
WebDAV in http= 110Mo/s
Where come the limitation?
Thks
DBX
Hi~ @JEROME_BOUDOT ,
Since HTTPS performs cryptographic functions, it can generally be slow.
In particular, some models of Synology have very poor HTTPS speed.
Synology DS210, DS220 models, etc. may have a speed of 300Mbps or less when using HTTPS.
