I compared transferring files from a flash drive to Google Drive using RaiDrive and found it to be 10-15 times slower than direct transfer through the Google Drive client.
How can I resolve this issue?
Hi, Ranu Ratmaja.
Google Drive Client works with background uploads.
When you upload a file, Google Drive Client stores it locally and uploads it later.
You can click the Try Icon in Google Drive Client to see the upload waiting, and check your network speed when the upload actually starts.
RaiDrive uploads in sync with your file system as much as possible.
Therefore, RaiDrive will complete the upload when you finish copying in Explorer.
Google Drive Client only stores locally after copying from Explorer, and uploads later.
Please compare the actual network upload speeds.
Thank you.
