Local data to keep or not to keep question
Hello
May I ask that the raid driver is directly uploaded to the cloud space, is there an option to keep a copy on the local computer?
Let me ask again, if it can be saved locally, is it possible to set the upper limit of the data saved locally, or customize which files are saved locally?
Hi~ @Jackey_Chung ,
RaiDrive caches data from all uploads/downloads.
All file data is cached and will be deleted after a period of inactivity (this time can be changed in the settings).
Also, if you disconnect a drive, we delete all cache on that drive.
The maximum amount of cache is not limited for best performance.
Therefore, make sure you have enough free space on your disk with the appropriate cache.
For example, if you upload a file that is 100 GB in size, you must have at least 100 GB of free disk space for it to upload.
You can change where the cache is located in your settings.
Excuse me,
if you restart or switch windows login account, will the temporary files be cleared?
Hi~ @Jackey_Chung ,
Temporary files are erased when the drive is disconnected, so restarts will erase them.
