Issue with Connecting Backblaze Service - Need Help
I’m having trouble connecting Backblaze to RaiDrive. I’m able to log in using my access keys in the RaiDrive editor, and the bucket is detected correctly. However, when I try to connect, it asks me for the access credentials again, as if it doesn’t remember my login and key.
I tested the same credentials in S3 Browser, and everything works fine there, so I don’t think it’s an issue with Backblaze or my credentials.
Has anyone encountered a similar problem or has any idea how to fix this?
Thanks in advance for any help!
Hi @luke124234,
Could you share a screenshot of the drive properties without credentials and endpoint?
It seems I don’t see endpoint field?
2024-09-19
We sent an email with a patch for this issue.
If you have any troubles, please let us know.
The patch fixed the issue. Thanks!
