this is the follow up issue for this updated version
Hi~ @vkldayne ,
We’re trying to verify what you’re talking about.
A full log file(C:\ProgramData\OpenBoxLab\RaiDrive\log) is required to confirm the exact issue.
If you send us the log file by e-mail(support@raidrive.com), we will check it and let you know again.
Hi~ @vkldayne ,
Thanks for sending the log file.
We will check the log file and tell you again.
For security reasons, the log file has been deleted.
Hi~ @vkldayne ,
We’ve made a new patch that fixes the issue you mentioned.
It would be a great help if you update, test, and let us know the results.
