After a problem with my pc i cant use any longer rai drive . I try to uninstall and reinstall but the problem is here.
Hi~ @Christopher ,
Uninstall RaiDrive and check if any files are left in the paths below, if so, you will need to remove them all and try installing RaiDrive again.
- C:\Program Files\OpenBoxLab
If the installation fails even after uninstalling everything, please email(support@raidrive.com) us the log file generated when the installation fails.
Just now , i had send an email with the log files and a screenshot of the error.
Hi~ @Christopher ,
We’ve sent you a response via email.
Please check your email.
Dear Team , good morning .My problem resolved .Thank you for the time and support.
