how to download from onedrive via ridrive ?
File downloading from OneDrive using the rdrive requires first authenticating and linking one’s OneDrive account to the rdrive tool. After such authentication, rdrive commands can then be used to access and download the files. The commands would usually look something like rdrive download <file_path> where <file_path> stands for the path of the file or folder on your OneDrive. Check whether rdrive is properly set up and then read the documentation for any instructions on setup and usage based on the version you are working with.
