Really like the programme and works exactly as described. The only challenge I have noticed is the GPS metadata is missing from all of my Photos using this tool. I assume this is due to the Google Photo’s API limitation, any workaround? I would want all othe meta data from my photos, GPS being the most critical.
Hi~ @cdmachuk-trap,
Thanks a lot for your report.
Unfortunately, Google Photos API does not support location(GPS) metadata.
If you want to download the image retaining all the EXIF metadata except the location metadata, concatenate the base URL with the
dparameter.
