I faced up with one issue with WebDav mapped drive. If try to copy folder that start with dot in beggning of its name to mapped drive I got error. It is not my WebDAV config issue as I can copy such folders via http without any problem. What can be wrong?
Hi, @Denis_Demchenko
If no error message appears after copying a folder in Explorer, the copy was successful.
RaiDrive sets the hidden attribute for files or folders beginning with a dot.
Therefore, if Explorer is set to its default settings, they may not be visible.
Try setting Explorer to show hidden files.
Please refer to the link below:
If an error occurs while copying a folder, please compress the log folder below and send it to support@raidrive.com.
- C:\ProgramData\OpenBoxLab\RaiDrive Mount\log
If an error occurs when compressing the log folder, copy the log folder and then compress the copied folder.
Thank you,
