Hi
Additional Comments to my response above:
For comment 1), I just found out that timestamp is also not preserved when using standard copy/move. Only when TeraCopy is used, all timestamps are exactly same with the original files and folders.
For comment 2), I could replicate the errors. Please find the log below, (only the [WARN] and [ERROR] ones)
In âservice.logâ file,
2020-03-21 04:32:44.778 [WARN] GoogleTeamDrive API : Google Team Drive : Upload Error : Forbidden Data :
2020-03-21 04:34:15.105 [ERROR] GoogleTeamDrive API : Google Team Drive : GetSpaceInfo : Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"GetAbout","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 04:35:55.376 [WARN] GoogleTeamDrive API : Google Team Drive : Upload Error : Forbidden Data :
2020-03-21 04:36:04.117 [ERROR] GoogleTeamDrive API : Google Team Drive : InitializeUpload Error : Response : {
"error": {
"errors": [
"domain": "usageLimits",
"reason": "rateLimitExceeded",
"message": "Rate Limit Exceeded"
"code": 403,
2020-03-21 04:36:04.117 [ERROR] ExtensionActionInfo:GoogleTeamDrive (Google Team Drive : ShellCopyUpload : API Copy Exception : C:\Users\SARUN\Desktop\āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ\āļĢāļļāļāļ āļēāļ\20191028_195820.mp4 -> /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4 : Copy Error : {"WinErrorCode":1237,"NotifyErrorCode":204,"RaiException":"","Filename":"/sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 04:44:35.247 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/sarundear","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 04:48:55.157 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/sarundear","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 04:53:15.163 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/sarundear","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 04:56:14.048 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/sarundear","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 05:18:24.946 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/sarundear","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 05:27:05.228 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 05:37:25.128 [ERROR] GoogleTeamDrive API : Google Team Drive : GetChangeStart Exception : {"WinErrorCode":1237,"NotifyErrorCode":108,"RaiException":"","Filename":"/","WebResponseCode":403,"HttpException":"403 Rate Limit Exceeded for file : rateLimitExceeded","HttpReferenceMessage":{"error":{"errors":[{"domain":"usageLimits","reason":"rateLimitExceeded","message":"Rate Limit Exceeded"}],"code":403,"message":"Rate Limit Exceeded"}}}
2020-03-21 05:41:26.158 [ERROR] GOOGLETEAMDRIVEFILE FILE : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4 : CacheFile Read Failed : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
2020-03-21 05:41:26.158 [ERROR] FILESYSTEM : Google Team Drive : Read Fail : Exception : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
2020-03-21 05:41:30.912 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:41:30.914 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:41:30.915 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:41:45.298 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:41:54.054 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:41:54.055 [WARN] GoogleTeamDrive (Google Team Drive) : OpenHandle : Shell Uploading : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4
2020-03-21 05:42:07.077 [ERROR] GOOGLETEAMDRIVEFILE FILE : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4 : CacheFile Read Failed : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
2020-03-21 05:42:07.077 [ERROR] FILESYSTEM : Google Team Drive : Read Fail : Exception : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
2020-03-21 05:42:08.707 [ERROR] GOOGLETEAMDRIVEFILE FILE : /sarundear/Family Share/āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ/āļĢāļļāļāļ āļēāļ/20191028_195820.mp4 : CacheFile Read Failed : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
2020-03-21 05:42:08.707 [ERROR] FILESYSTEM : Google Team Drive : Read Fail : Exception : {"WinErrorCode":87,"NotifyErrorCode":301,"RaiException":"ReadFile : EndPosition too large"}
In âcenter.logâ file,
2020-03-21 04:32:47.183 +07:00 [WRN] ext-fail-copy to S:\sarundear\Family Share\āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ\āļāđāļēāļĢāļąāļāļĐāļēāļāļĒāļēāļāļēāļĨ.xlsx from C:\Users\SARUN\Desktop\āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ\āļāđāļēāļĢāļąāļāļĐāļēāļāļĒāļēāļāļēāļĨ.xlsx <- {"WinErrorCode":5,"NotifyErrorCode":204,"RaiException":"","Filename":"āļāđāļēāļĢāļąāļāļĐāļēāļāļĒāļēāļāļēāļĨ.xlsx","WebResponseCode":403,"HttpException":"403 Forbidden Error : ","HttpReferenceMessage":""}
2020-03-21 04:35:56.637 +07:00 [WRN] ext-fail-copy to S:\sarundear\Family Share\āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ\āļĢāļļāļāļ āļēāļ\20191028_193514.jpg from C:\Users\SARUN\Desktop\āđāļāđāļāļāđāđāļ§āļĒāļŠāļĄāļāļļāļ\āļĢāļļāļāļ āļēāļ\20191028_193514.jpg <- {"WinErrorCode":5,"NotifyErrorCode":204,"RaiException":"","Filename":"20191028_193514.jpg","WebResponseCode":403,"HttpException":"403 Forbidden Error : ","HttpReferenceMessage":""}
And the files were not copied properly as shown below.
While the file size for the mp4 file seems to show correctly, but it cannot be played! That means itâs not correctly closed when copying.
Please investigate this.
Thank you.
