hello,
i’m using individual licence via WebDAV to access AliYunpan(https://aliyundrive.com/). i found some files and folder missing in some folder. The file type include video(.mkv).
i try to using other WebDAV app to access aliyun, no problem.
any idea?
thanks.
Hello, chocolate5215.
Please compress the log folder below and send it to support@raidrive.com.
If possible, please capture the drive settings screen and send it to me.
Thank you.
mail sent. thanks for your help.
[sloved] The problem locate on aliyundrive. for now, you can NOT using ’ " < > & in your filename. then, all missing file appear immediately.
thanks for the support team/person.
regards.
