File Lock function
We are a small team of five and use pCloud for our data storage. Unfortunately, due to the lack of a file locking feature, collaboration has been somewhat complicated.
I came across RaiDrive and have a few questions about it:
  • It is mentioned that file locking is available, but only for Office programs. Does the file lock also work with other applications, such as CAD, 3D, or photo editing software?
  • Can I use RaiDrive on macOS with emulation software?
  • Are there solutions available for teams working on both macOS and Windows?
  • How exactly does the file locking feature work? Is it instant?
  • If one team member opens a file, will other members see this in real time?
  • Is there any delay in the file locking process? If so, how long?
  • Does the system provide visual feedback to indicate that a file is currently being edited by someone else?
Looking forward to your response. Thank you!
Hello @franz_stibli
I’m sorry for the delay in responding.
These are the answers for your questions.
The File Lock feature has been verified to work with Office programs and major Adobe products (Photoshop, Premiere Pro, AfterFx, DreamWeaver, illustrator). The RaiDrive Preview version also supports AutoCAD.
It has been confirmed that RaiDrive can be used with Parallels.
The RaiDrive macOS version is currently under development. File Lock functionality with Parallels has not been tested yet, but it is expected to work if both use the same Office version and the File Lock option is enabled.
File Lock works by checking if a Lock file exists on the remote drive when an Office file is opened. This process may take a small amount of time depending on the characteristics of the remote drive and the network conditions.
There is no immediate way to confirm if someone else has opened the file.
The time required for File Lock checking and creation depends on the network conditions but is generally within 1-2 seconds.
There are no methods or features provided to notify when another person edit a file.
If you have any further questions, please let us know.
Best regards,
