When I try to rename files on a remote server, it says “you need authority from Everyone”.
The connection to the problematic server is relative slow (the server is overseas). However, when it comes to a relatively fast server (a local server or a domestic server), this problem does not show up. I guess the problem is caused by an unreasonable timeout value. Is there a way to fix this?
the log:
2022-03-26 02:50:38.771 [ERROR] SFTP (<ServerName>) : Rename/Move : /a.txt => /sd.txt : Rename Failed : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Directory/File Fail","Filename":"/a.txt=>/sd.txt","InnerException":"Failure; Failure."}
2022-03-26 02:50:38.771 [ERROR] FILESYSTEM : <ServerName>: RenameOrMoveFile Fail2 : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Failed"} : \Device\HarddiskVolume3\Windows\explorer.exe
2022-03-26 02:50:39.179 [ERROR] SFTP (<ServerName>) : Rename/Move : /a.txt => /sd.txt : Rename Failed : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Directory/File Fail","Filename":"/a.txt=>/sd.txt","InnerException":"Failure; Failure."}
2022-03-26 02:50:39.179 [ERROR] FILESYSTEM : <ServerName>: RenameOrMoveFile Fail2 : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Failed"} : \Device\HarddiskVolume3\Windows\explorer.exe
2022-03-26 02:50:41.591 [ERROR] SFTP (<ServerName>) : Rename/Move : /a.txt => /sd.txt : Rename Failed : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Directory/File Fail","Filename":"/a.txt=>/sd.txt","InnerException":"Failure; Failure."}
2022-03-26 02:50:41.591 [ERROR] FILESYSTEM : <ServerName>: RenameOrMoveFile Fail2 : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Failed"} : \Device\HarddiskVolume3\Windows\System32\dllhost.exe
2022-03-26 02:50:41.999 [ERROR] SFTP (<ServerName>) : Rename/Move : /a.txt => /sd.txt : Rename Failed : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Directory/File Fail","Filename":"/a.txt=>/sd.txt","InnerException":"Failure; Failure."}
2022-03-26 02:50:41.999 [ERROR] FILESYSTEM : <ServerName>: RenameOrMoveFile Fail2 : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Failed"} : \Device\HarddiskVolume3\Windows\System32\dllhost.exe
2022-03-26 02:50:43.642 [ERROR] SFTP (<ServerName>) : Rename/Move : /a.txt => /sd.txt : Rename Failed : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Directory/File Fail","Filename":"/a.txt=>/sd.txt","InnerException":"Failure; Failure."}
2022-03-26 02:50:43.642 [ERROR] FILESYSTEM : <ServerName>: RenameOrMoveFile Fail2 : Exception : {"WinErrorCode":5,"NotifyErrorCode":211,"RaiException":"Rename Failed"} : \Device\HarddiskVolume3\Windows\System32\dllhost.exe
