Não estou encontrando como inserir direitos de acesso nas pastas do Google Drive.
É possível fazer ou não?
Hi~ @suporte,
Honestly, we don’t understand what you mean.
Could you describe more with screenshot?
Okay, I’ll change the question.
I want to share the Google Drive folder with others
I have a PRO subscription.
How do I get someone else to receive the shared folder?
I tried to install it on her computer and it only works if I log in with my credential, hers is useless.
Can you help?
Thanks a lot for your detailed description.
To share a folder with other PC on the local network,
Local Disk and choose Public option
File Explorer and go to the parent folder of the folder which you want to shareProperties menuSharing tab and click Share... button
