Device driver installation failed. (5)
I have installed both the VC library and the NET library, but I still cannot start the application normally
Hi, himekoexg.
The driver installation failed due to lack of administrator rights.
Please try installing the driver manually.
Run CMD with administrator rights.
After completion, reboot Windows.
And try installing again.
I ran the command RaiDrive.Service.x64.exe /install /v as an administrator, but there was no output. Then I restarted the device, and the application still popped up the error Device driver installation failed. (5)
According to the log, it still says that you do not have administrator rights when installing the driver.
I suspect that the driver installation is blocked by an antivirus or other process.
Please check if there is an antivirus or permission-related process, and stop the related process and try again.
Also, please do not attach the log file here, but send it to support@raidrive.com.
If the problem is not solved, please try installing the Preview version.
The Preview version may be able to install because it is a new file system driver.
Please select Preview from the link below to download and install the installation version that suits your system.
Please let me know the result.
