Delphi Dev environment can't create output folders
I am using the free version of RaiDrive, with ASUSTOR NAS, connecting
to mapped drives via WebDAV
I am correclty signed in / attached, and I own the folders on the drive.
When tyring to run my Dev Environement and compile / run an app in
debug mode, or try to just build the project, I get an
error that my files / folders cannot be created.
** UPDATE **
I had to upgrade to the paid trial to fix the write problem, but I still get
errors that debug environment cant attach.
Don’t know if it’s the RaiDrive software or my ASUSTOR NAS,
but this software is adding a lot of overhead to my resouce usage.
Hi @David_Barajas
Please compress the log folder below and send it to support@raidrive.com.
If an error occurs when compressing the log folder, or if the service.log file is missing from the compressed result, please copy the log folder first and then compress the copied folder.
If you send us the logs, we will analyze them and get back to you.
Thank you for sending the logs.
Please test again using the test version below.
Please send the logs again if an issue occurs.
If there are no issues, and you are only using WebDAV, please cancel your paid subscription and use the free version.
Please let us know the results.
