Is it possible to have all cloud login credentials reflect on two different PCs using the same account. Logins and passwords? Or is there a way to backup these credentials and restore them on a different PC so that inputting user name such as pCloud, Google Drive or others doesn’t need to be repeated for each account? If so what is the filename and location where this data is stored. Thanks in advance.
Hi~ @maddogdj,
RaiDrive does not support to export or import the information of drives for now.
We will consider this feature for the future version.
Thanks a lot for your inspiration.
