I’m using RAIDRIVE 2023.9.170 trial version.
It is installed on Win2k19 SRV Standard edition (for testing purposes)
The disk using WebDAV is attached from Synology NAS
(RS422+, DSM 7.2-64570 Update 1)
Total space 1Tb, Free space 800Gb
I’m using Windows File Explorer.
I faced the issue when was trying to upload to the disk backup file (size 240Gb):
windows error message: "There is not enough free space in destination folder).
15Gb files uploading well.
How can I resolve the issue?
May be there is trial / WebDAV limitations for file transfer size ?
Hi. any ideas there?
Hi @Stanislav_Erman,
RaiDrive use the cache file on uploading a file.
If file size to upload is greater than free space on your disk, it will be failed.
