Error 400: invalid_request
Missing required parameter: client_id
this is all i keep getting
Hi~ @Edward_Hargreaves,
Could you let us know what kind of storage?
I have been using Raidrive for over 12 months without a problem upgraded to the latest version and just continuous error 40 invalid request. I only use it for Gdrive personel
Could you post a screenshot and URL when a browser (or RaiDrive) displays “invalid_request” message?
How long does it take to get a response from you?
Please let us know the whole URL from your browser as below.
https://accounts.google.com/o/oauth2/v2/auth/oauthchooseaccount?response_type=code&prompt=consent&access_type=offline&include_granted_scopes=false&scope=openid%20email%20https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fdrive&client_id=776566199448-1qph55cg3cuhq3voh1cotrc7cfrsfihu.apps.googleusercontent.com&redirect_uri=https%3A%2F%2Fwww.raidrive.com%2Fv2.0%2Fcloud%2Fcommon%2Fwelcome&state=WpzNlmDaldSrQhKyLpRugKnqRt9xPInK97eQK4QxUxKo18LphQMx%252ByyIFjdcS8cEPRGS3JYq23x9Ip35L1PRezT8SRISXnYZp1glOHNHyJtEBYiB3KkwuLS1bAKewbW3BjP%252B3VnbHm7EmsBC6SyZK%252FIQW8i4Go6Uw29STI%252FGdLjWLPTyEk2q4bY4i2fg5qoQNt01lriRrE2%252FJj0WYbzzhVigCgN44180dH9gLt1r2WJaAthbdtg1DdZDLlbLw9Xr&hl=ko&flowName=GeneralOAuthFlow
Where do I download the previous version of Raidrive. Ive given up this latest version is a joke. Ive tried 3 other drives which connect straight away, so the fault is at your end. What was once good is now useless
Take it easy. Making software that can handle so many connection protocols is not easy.
They do a great job.
We should support them as best we can.
You can download the old version 2020.2.12 here: https://download.cnet.com/RaiDrive/3000-18500_4-77759212.html
Let them know if the bug didn’t exist with this version
This is the latest error from your previous version
Missing required parameter: redirect_uri
This issue is a very abnormal case.
To solve this, absolutely we NEED the whole URL from your browser.
Thank you for your reply.
But this is the result and is not what I need.
Please refer to the following.
Same error Error 400: invalid_request
Could you solve it? I have the same error.
@kevin.andresmartinez, @Edward_Hargreaves, @Edward_Hargreaves1
This kind of message cannot happen in a normal environment.
RaiDrive delivers two parameters directly to the default web browser on your PC.
We carefully recommend clearing browser caching (Ctrl+Shift+Del).
