I have a folder shared with me, the author of that folder add files to it daily.
The new files can be seen in the Google Drive Dashboard “Shared with me” section.
But the new file cannot be seen in the “Shared with me” drive that I setup using RaiDrive.
I tried Refreshing etc
So I then Went to google dashboard shared with me section and then removed the folder there, waited for the folder to get removed from Raidrive Disk and then revisited the shared link and then finally I could see the updated file in the Raidrive Disk.
How do I fix this issue, I want the Raidrive disk to automatically update itself instead f going thorough all this mess ???
Disconnecting and reconnecting the Drive in RaiDrive Dashboard made the new file appear in the Shared with me section, but having to do this each time is not the best option.
Could you send log files (C:\ProgramData\OpenBoxLab\RaiDrive\log) when it happened?
In our lab it could not be reproduced.
If we find out what the reason is, it will be fixed ASAP.
Your log said that when RaiDrive retrieves the change from the remote, Google responses “Internal Error”. In this case unfortunately only Google knows why this happens.
"error": {
"errors": [
"domain": "global",
"reason": "internalError",
"message": "Internal Error"
"code": 500,
// from 9772, 9773, 9786 line in service.log.2
