How to solve this problem, Daily some users go through this.
I reset the user’s internet, I remove and install the raiddrive program and the problem persists.
Hi~ @Golden_Raidrive ,
If there are 15 licenses and 15 users are using it, if the 16st user logs in, the first logged in user will be logged out. For smooth usage, we recommend subscribing to 1-2 more licenses than the number of users.
I have 15 licenses, and each user has their individual license with their own login and password. The error occurs on different users.
The RaiDrive licensing model is a floating license and you can check your total usage at the following link.
We will also consider more sophisticated license management systems.
