Hello all,
I have RaiDrive installed on my laptop (Win 10) and connecting to a SFTP works fine as long as I am on the same network. But when I try it in homeoffice, I get an error that the server gave a wrong answer. For sure i did not change the Passwort / Username et cetera.
I honestly don’t know where to start looking for the error, or what information you guys need from me so you can get a better picture of my error. I hope that maybe someone has an idea anyway. Please ask me for the data you need!
Many thanks in advance!
Greetings from Germany,
Marvin
Hi~ @mkellermann ,
If it works fine in the same network but not in another network, it is usually a issue with the port forwarding setting of the router.
Please check the port forwarding setting of your router device.
If the issue persists, please e-mail(support@raidrive.com) the log file(C:\ProgramData\OpenBoxLab\RaiDrive\log).
Thank you for your reply. I do not have a folder or file named log. :-/
Hi~ @mkellermann ,
The location of the log file is “C:\ProgramData\OpenBoxLab\RaiDrive\log”.
- How to access the ProgramData folder.
After moving to Local Disk (C:), if you check Hidden items in the View menu at the top of the explorer, the ProgramData folder is displayed.
