I can’t find the option to enter the bucket region (fr-par) so when I click Connect, it threw this error:
Is there any way to manually enter the bucket region (the refresh button doesn’t work)?
Thanks.
Thanks.
Hi~ @Duc_DH ,
Two pieces of information are required to confirm the issue.
If you send us two pieces of information by e-mail(support@raidrive.com), we will get back to you after checking.
Thanks for the instruction. I sent those information.
