I created 3 mountables drives and each time I start raidrive, I got 3 internet explorer windows asked for select microsoft account. Then I have to select 3 times the same account.
I would like this to be automatic
Thanks
Thanks
Hi~ @e.eriale,
If you check “Connect using different credentials”, RaiDrive acts like your report.
Could you try to un-check?
