Hi, i would like to know if raidrive can retry the connection after it fails to connect with any error, like 429 or 504. Is there any auto try reconnect after x seconds?
Hi, Mario_Ritzmann.
RaiDrive defaults to a repeat request when a 429 or 504 error occurs.
Depending on the case requested by the file system, it may be performed only once, or may be repeated several times depending on importance.
However, it does not repeat indefinitely, and if it fails after several iterations, it throws an error.
If an error occurs when connecting the drive, it will not automatically reconnect.
Thank you.
