I’m using the drives loaded by RaiDrive as destination for my Windows Libraries and it all works just fine… until I restart the computer. After that the libraries are reseted.
I believe it is because RaiDrive doesn’t load earlier enough to be recognized by the system, so I wonder if there is any way to load RaiDrive as soon the boot process starts. If this is not possible, please consider a new feature to facilitate the use of drives with libraries.
Thanks!
